what is the use of this command & without Impact ?
Answered Question
Feb 21st, 2008
What is the use of this command If I disable what will be the impact?
resource policy
clock timezone IST 5 30
no network-clock-participate wic 0
no network-clock-participate wic 1
Correct Answer by royalblues about 9 years 2 months ago
resource policy
Not exactly sure what it does
Configures your timezone name to IST and the offset is set to 5hrs 30mins from the UTC(universal coordinated time)
Restricts the network module or WIC to use only its own clock signals
same as above
Narayan
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Fri, 02/22/2008 - 00:58
  • Green, 3000 points or more
resource policy
same as above
Narayan
