Push-to-talk with Nortel 6140 wireless handset + WLC 4400
Feb 22nd, 2008
Hi!
I'm trying to configure the push to talk feature built in to the Nortel 6140 wireless phone handset, but can't seem to make it work with our WLC 4400.
This is from the Nortel documentation:
"he WLAN Handset 2211 and WLAN Handset 6140 join the IP multicast
stream through Internet Group Management Protocol (IGMP) v1 reports.
Each handset continues to send IGMP reports as long as PTT is enabled,
so the IP multicast state is maintained in the network, even when there is no
active use of the PTT feature. The multicast address used to support PTT is
224.0.1.116, and the port is 5001".
I've tried to configure the WLC as described (enable multicast with address 224.0.1.116), but still it's no go.
Anyone got any experience with this?
sethgarnar Wed, 03/12/2008 - 07:32
Were about to deploy the same phones on our network. From what I read you need to enable multicast on all the vlans that the AP's connect to as well.
Darren Ramsey Wed, 03/12/2008 - 08:46
  • Silver, 250 points or more
That looks like the Spectralink group address. On the controller enable multicast and use an administratively scoped address in the 239.192.0.0/14 range, and enable multicast routing between the controller an APs. The phone group address should not be the same as the WLC/AP group address. I have also seen multicast-unicast mode work as well, but might flood your network.
g.rienstra Fri, 05/02/2008 - 06:30
Use unicast in stead of multicast from the controller as a test and do nothing on the LAN.
Reg
Goen
