user authentication for vpn on cisco pix 515
Feb 22nd, 2008
Hi all. Below is part of my current config.
ip local pool vpnpool 192.168.10.151-192.168.10.170
pdm location x.x.x.x 255.255.255.248 outside
pdm location 192.168.10.0 255.255.255.0 inside
pdm location 192.168.10.2 255.255.255.255 inside
pdm location apsrv 255.255.255.255 inside
pdm location x.x.x.x 255.255.255.255 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp x.x.x.x ssh applsrv ssh netmask 255.255.255.255
0 0
access-group 110 in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa authorization command LOCAL
http server enable
http x.x.x.x 255.255.255.248 outside
http 192.168.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10 set peer x.x.x.x x.x.x.x
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp client configuration address-pool local vpnpool outside
isakmp nat-traversal 3600
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup sevpn address-pool vpnpool
vpngroup sevpn dns-server 192.168.10.2
vpngroup sevpn default-domain abc.edu.sg
vpngroup sevpn split-tunnel 101
vpngroup sevpn idle-time 1800
vpngroup sevpn password ********
vpngroup split-tunnel idle-time 1800
telnet 192.168.10.0 255.255.255.0 inside
telnet apsrv 255.255.255.255 inside
telnet timeout 5
ssh x.x.x.x 255.255.255.248 outside
ssh timeout 5
console timeout 5
vpdn enable outside
username administrator password grYy2xe.MAY6tCua encrypted privilege 15
username user1 password xxx privilege 5
username user2 password xxxx privilege 3
privilege show level 0 command version
privilege show level 0 command curpriv
privilege show level 3 command pdm
privilege show level 3 command blocks
privilege show level 3 command ssh
privilege configure level 3 command who
privilege show level 3 command isakmp
privilege show level 3 command ipsec
privilege show level 3 command vpdn
privilege show level 3 command local-host
privilege show level 3 command interface
privilege configure level 3 command ping
privilege show level 3 command uauth
privilege configure level 5 mode enable command configure
privilege show level 5 command running-config
privilege show level 5 command privilege
privilege show level 5 command clock
privilege show level 5 command ntp
privilege show level 5 mode configure command logging
privilege show level 5 command fragment
terminal width 80
Cryptochecksum:xxx
: end
Right now my users can vpn into my office network via vpn client. But they are not prompted for username and password. Can i enable the user authentication by stating the below commands? Do i need to add anything else?
aaa authentication enable console LOCAL
username <user_name> password <secret_pwd> privilege 0
johnd2310 Mon, 02/25/2008 - 20:02
  • Silver, 250 points or more
Configure aaa and then enable Xauth with the
"crypto map client authentication" command
John
