Unity 4.2 DOHPropTest password ?
Feb 22nd, 2008
I need to use DOHPropTest to fix a problem, the help advises ...
"If a support person wants you to use this tool for them they will provide you with a password"
Does this refer to TAC ? Is there a default password I can change (assuming I am the support person ?)
The issue I have is ...
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a0080910871.shtml
And I want to use option 1 in case we do require the service in the future.
Overall Rating: 5 (3 ratings)
Brandon Buffin Fri, 02/22/2008 - 06:06
  • Purple, 4500 points or more
The password is:
(100-month)(month + day)
So, today's password would be 9824.
Hope this helps. If so, please rate the post.
Brandon
roy_fisher Fri, 02/22/2008 - 06:43
Brandon,
That was spot on - thanks.
Though now I have the problem the mailbox the fix said to modify does not exist nor does the AD user also mentioned in the fix !
Think it's time to post a new question.
Thanks for your help.
Roy
