Strange transfering problem
Feb 22nd, 2008
Hi Everyone,
I am having a problem with transfered calls, I am sure I have configured correctly for Full-consult transfers but the system is doing blind.
I have been tearing my hair out over this for the last few days and would be very greatful for any help.
scottwclarke Fri, 02/22/2008 - 03:02
Just thought I should add I have a 2801 with 16 DSP's, running cme 4.2 on version 12.4(11) XJ4
rob.huffman Fri, 02/22/2008 - 05:43
Hi Scott,
Is this problem with all phones or just the ones not configured with the dual-line command? My guess is that adding the dual-line to all ephones will resolve the problem.
A dual-line ephone-dn has one virtual voice port and two channels to handle two independent calls. This capacity allows call waiting, call transfer, and conference functions within a single ephone-dn. Dual-line mode is supported on all phone types, but is not appropriate for voice-mail numbers, intercoms, or ephone-dns used for message-waiting indicators, paging, loopback, or hunt groups. Overlays of single-line hunt groups onto dual-line buttons are supported.
Ephone-dns are created in single-line mode if the dual-line keyword is not used. Changing an ephone-dn from dual-line mode to single-line mode (and vice versa) requires that you delete the ephone-dn and then recreate it.
The following example enters ephone-dn configuration mode to create the ephone-dn 5576:
Router(config)# ephone-dn 1
Router(config-ephone-dn)# number 5576
Router(config-ephone-dn)# exit
The following example creates an ephone-dn with the number 1001 in dual-line mode. The no huntstop command allows calls to continue to hunt to other ephone-dns if this one is busy or does not answer. The huntstop channel command disables call hunting to the second channel of this ephone-dn if the first channel is busy or does not answer.
Router(config)# ephone-dn 10 dual-line
Router(config-ephone-dn)# number 1001
Router(config-ephone-dn)# no huntstop
Router(config-ephone-dn)# huntstop channel
From this good CME doc;
Hope this helps!
