Logging to DMZ 5.6.7.8 tcp/1468 is disabled
Feb 22nd, 2008
Dear all,
we have configured another logging host
logging on
logging trap debugging
logging console debugging
logging facility debugging
logging host INSIDE 1.2.3.4
logging host DMZ 5.6.7.8 tcp/1468
but "show logging" is saying:
logging to DMZ 5.6.7.8 tcp/1468 is disabled
Do we have to define a new access list now?
THX, Rainer
abinjola Fri, 02/22/2008 - 08:53
Is it Pix or ASA ? which version ?
Disable the command logging to DMZ 5.6.7.8 tcp/1468
and add it on UDP, does it still show disabled ?
no logging host DMZ 5.6.7.8 tcp/1468
logg host inside DMZ 5.6.7.8
brainer12 Fri, 02/22/2008 - 09:39
@abinjola:
1. PIX 6.3
2. logg host inside DMZ 5.6.7.8
you mean: logg host DMZ 5.6.7 isn't?
3. I thought that the PIX is only using TCP
packets for logging
THX, Rainer
abinjola Fri, 02/22/2008 - 09:44
yes I meant logg host DMZ..<.>
is it working now ..issue resolved ?
