WISM backup via TFTP
Feb 22nd, 2008
We are attempting to create an automated backup of our WISM controllers via a script and CLI. We had some questions regarding this:
- What is the command to show the file system? We can't see what file(s) are available to backup.
- We downloaded a file named "run-config" but it seems to be a binary file instead of a text file. Is this normal?
Thanks in advance.
rob.huffman Fri, 02/22/2008 - 06:21
Hi Trony,
The backup file will be a Binary file :)
Here are some references to this;
These are the best practices for General Administration:
In general, before any upgrade it is a good idea to do a binary backup of the configuration. WLCs support the conversion of older configuration information into new versions, but there is no support for the reverse process. This applies both to major or minor version changes.
The use of a newer configuration into an older release might lead to missing settings (access lists, interfaces, and so forth), or on incorrectly working features. If you need to downgrade a controller, it is advisable that after the downgrade, you clear the configuration, configure back the management interface address, and load the binary backup file by TFTP.
Hope this helps!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
