Route Pattern vs RL and RG
Feb 22nd, 2008
is it normal to use many RL and RG?
I used Route pattern PRI with RL not gateway, but in the RTMT I see message
"Most Recent Alert Raised: At 14:33:20 on 02/22/2008 on cluster StandAloneCluster. Number of RouteListExhausted events exceed 0 within 60 minutes.
There are 12 RouteListExhausted events (up to 30) received during the monitoring interval from 14:32:51 02/22/2008 to 15:32:51 02/22/2008:
RouteListExhausted Originated from CallManager
Route list name: Ks_RL
What does it mean?
MARTIN STREULE Fri, 02/22/2008 - 06:32
  • Silver, 250 points or more
TAC case collection:
Solution # K20653428
Title
The Route list Exhausted event appears in the Cisco CallManager Event Viewer
Core Issue
This issue can occur if an available route is not found in the indicated route list.
If the call fails on the current gateway, Cisco CallManager attempts to extend the call to the next route in the route list. This occurs until it reaches the last route. If the call cannot be completed with the last gateway, the Route List Exhausted event is logged.
These are possible reasons for a failure on the current gateway:
Unallocated number, such as a non-existing destination
Busy user
Out of bandwidth
Gateway fails to respond to the call setup request
-> It does not necessarily mean that you lack gateways/channels...
You should look into the CDRs and debug the gateway and try to find the issue.
Hope that helps.
/Martin
