7206VXR - Out of band management via auxiliary
Feb 22nd, 2008
I'm trying to config my Cisco7206 VXR (IOS Version 12.2(31)SB9) to be reached over pstn on its auxiliary port through a modem.
Here's the very simple router config:
line aux 0
session-timeout 10
login local
modem InOut
transport input all
transport output all
stopbits 1
flowcontrol hardware
I'm able connect the router via pstn at the first call, then I disconnect the pstn call and then the AUX line remains always busy and I'm not able to connect anymore (I have to do a manual "clear line" or remote router reset).
It seems remains still open a kind of conversation between router AUX and modem...
Any idea to solve the problem ?
Tks
Ric
owillins Thu, 02/28/2008 - 11:52
  • Silver, 250 points or more
1.The AUX port on Cisco routers is either RJ-45 or DB-25. If the AUX port is RJ-45, use a flat-satin rolled RJ-45--RJ-45 cable (part number CAB-500RJ= ), which is usually provided with every Cisco router for console connections. You also need an RJ-45 to DB-25 adapter marked "MODEM" (part number CAB-25AS-MMOD) to connect the rolled cable to the DB-25 port on the modem.
2. if your router has a DB-25 AUX port, use a straight-through DB-25Female - DB25Male RS-232 cable to connect the modem to the router.
Use this document.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094bbc.shtml
