WCCP and multi-hop
Answered Question
Feb 22nd, 2008
Is it possible to have a routed path (several Layer-3 hops) between a wccp router and a cache engine ? As far as I remember, a GRE tunnel is established between the router and the cache, right ?
Thank you
Yves
Correct Answer by dstolt about 9 years 5 months ago
Yves,
Yes, when you use GRE, you can be serveral L3 hops away, however, increasing latency will reduce performance. You also want to prevent accidental re-interception of your egress traffic.
Hope that helps,
Dan
Overall Rating: 5 (1 ratings)
Correct Answer
dstolt Fri, 02/22/2008 - 10:51
  • Cisco Employee,
Yves,
Hope that helps,
Dan
