VLAN question
Feb 22nd, 2008
I setup two ethernet switches (CAT 3750) on 8/F and 32/F. detail please check the attached file.
there are two fibers to be connected to each other. It has two VLANs on 8/F and 32/F. 192.168.12.0/24 and 192.168.24.0/24. how do I config the CAT to force the 192.168.12.0/24 traffic to fiber A and 192.168.24.0/24 go fiber B?
any suggestion?
rdgs
Overall Rating: 3.3 (3 ratings)
Jason Fraioli Fri, 02/22/2008 - 08:37
int fa 1/0/8
switchport trunk allowed vlan
int fa 1/0/32
anitachoi3 Fri, 02/22/2008 - 08:41
do I need to enable the spanning tree? if so, how to config it?
rdgs
Joseph W. Doherty Fri, 02/22/2008 - 08:43
I'm unfamilar with specifics for the 3750, but generally all you should need to do is drop one fiber into a port based VLAN for the one VLAN and the other fiber port into a port based VLAN for the other VLAN. I.e. don't trunk VLAN on either.
If you had more than two VLANs but still wanted to have one VLAN on one fiber and the other on the other fiber, you might trunk with VLAN filters. Need to be careful with what your implementation of spanning tree does.
[edit]
PS:
You might also consider channeling the two ports and passing both VLANs across them in a trunk. Doing so gives you redundancy, loss of one link won't cause loss of VLAN. Also, depending on traffic, both VLANs can share 2x bandwidth.
Edison Ortiz Fri, 02/22/2008 - 08:46
  • Hall of Fame,
    Founding Member
Replied on your first post
________________
If you are only going to deal with 2 Vlans, let's call 192.168.12.0/24 Vlan12 and 192.168.24.0/24 Vlan24.
Then on the switches, where you want traffic for Vlan12 to go just issue the following on the switchports
interface fx/x
switchport mode access
switchport access vlan 12
On the switchport where you want Vlan24 just issue:
interface fx/x
switchport access vlan 24
If you wanted to trunk the ports, issue the following:
interface fx/x
switch port trunk encapsulation dot1q
switchport mode trunk
switchport trunk allowed vlan 12
For Vlan12 and for Vlan24
interface fx/x
switchport trunk allowed vlan 24
One thing to keep in mind, I recommend going with the trunk if you plan on carrying more than one Vlan over that link. If you aren't then go with the access-vlan method.
HTH,
__
Edison.
anitachoi3 Fri, 02/22/2008 - 08:54
Hi edison,
the config is
interface f1/0/1
description VLAN 12
interface f1/0/2
description VLAN 24
interface f1/0/22
description 75xx router
interface f1/0/23
descrip fiber A, VLAN 12 traffic only
interface f1/0/24
descrip fiber B, VLAN 24 traffic only
any missing? how to enable the spanning tree?
rdgs
Joseph W. Doherty Fri, 02/22/2008 - 08:59
Believe you're going to want both ends of the link configured alike, i.e. both access port mode or both trunk mode.
anitachoi3 Fri, 02/22/2008 - 09:03
yes. I sure that the spanning must be config otherwise it may has major issue. I do not have any idea to enable it from CAT 3750. any idea or suggestion?
rdgs
Joseph W. Doherty Fri, 02/22/2008 - 09:36
Config guide for your software should provide all the details, e.g.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swstp.html#wp1096308
You might also consider using smartport macros, e.g.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swmacro.html
There's also the configuration assistants, but unsure what all they support.
PS:
I would recommend you start out with the IEEE 802.1w variant.
