Restart to Factory Cisco 2700 WLA
Feb 22nd, 2008
Hi.
Sorry, how can I reset the location server to factory defaults without the WCS?
It's only putting on consola User: "root" and Password: "setup" ?
Thanks.
ivillegas Thu, 02/28/2008 - 12:22
  • Silver, 250 points or more
First kill the processes that are running on the location appliance. Use the command ps -ax | grep locserv to find the processes and their . If you find any kill them using kill -9 . Then delete the config file to set stuff back to defaults:
rm /opt/locserver/db/linux/server-eng.db. Then restart the location server using the command /etc/rc.d/init.d/locserverd start.
