Multiple Authentication methods
Feb 22nd, 2008
Is it possible to have a 1130AG configured to authenticate users throught PEAP/MS IAS and to authenticate users through a local client access list with the same SSID? I know you can with different SSID's, but I need everything to be on the same vlan.
Scott Fella Tue, 02/26/2008 - 21:22
Yong is correct, started with 4.0, but you have to also make sure your profile name is different. Why would you want to put them on the same vlan. If you have one ssid using peap and then you want to create another ssid on the same subnet for a lesser security method, it kind of defeats the security on the subnet. You might as well put the lesser security method on a different subnet. Just my opinion though.
adamcdoan Wed, 02/27/2008 - 05:13
You're absolutly correct. I thought of that after I posted the question.
Trending Topics - Security & Network
