ATM behavior
I'm needing some engineering/ design help with ATM.
What I need to know is on an atm circuit with say 4 pvc's to four remote locations.
these pvc's are provisioned as UBR pvc's. Can I run up to the full bandwidth on any of the pvc's? or is the ATM t1 bandwidth split between the pvc's? If it is split that will mean that I can only run about 384k ( not including the cell tax) on each pvc.
Paolo Bevilacqua Fri, 02/22/2008 - 13:16
Hi, there is no bandwidth split and each pvc will be free to burst up to the configured cell rate without relation to others. You can configure pvc's with different priority o so on case of congestion cells from the prioritized one will be sent first.
