Need Help with Call Connector Server
Feb 22nd, 2008
I need help configuring the Unified Call Connector Server 1.3. I keep getting "Index list out of bounds (5)" errors when trying to configure. Is there a configuration guide that steps you through the setup?
martypearson Tue, 02/26/2008 - 10:58
You need to reboot the server so that the installation can finish installing. This error will occure if you run the Configuration Wizard before you reboot after installing. If you look at your Services, there will not be any installed or running for the UCC Server until it is rebooted.
