show running-config full
Feb 22nd, 2008
Can someone please tell me what the point of the "full" option to the "show running-config" command is, and what sort of information (specifically) might be hidden if you don't use this option when issuing the command? The IOS documentation doesn't say.
mohammedmahmoud Fri, 02/22/2008 - 11:43
The full keyword is the default option for the command, this makes, "show run" = "show run full", you can find below other details:
R6#show running-config ?
brief configuration without certificate data
class-map Show class-map information
full full configuration
interface Show interface configuration
linenum Display line numbers in output
map-class Show map class information
policy-map Show policy-map information
view View options
| Output modifiers
R6#show running-config in
R6#show running-config interface f0/0
Building configuration...
Current configuration : 122 bytes
interface FastEthernet0/0
ip address
duplex auto
speed auto
Mohammed Mahmoud.
gglynn Fri, 02/22/2008 - 13:31
Are you sure? Because most IOS commands don't have default options.
mohammedmahmoud Sat, 02/23/2008 - 06:39
Please always check the "Defaults" part in the DocCD for any command and you'll always find a default option, for example for this command i quote:
"The show running-config command without any arguments or keywords displays the entire contents of the running configuration file."
Mohammed Mahmoud.
