netflow basic question
Collin Clark Fri, 02/22/2008 - 12:47
  • Purple, 4500 points or more
You can see flows for multiple interfaces. You must configure each interface for netflow with the following command:
ip route-cache flow
I put that command at the top level; that is not as part of an interface and I have seen lots of flows when I do a sho ip cache flow. My guess is that I am looking at all interfaces and if I wanted to troubleshoot one interface then I would apply the ip route cache flow to a specific interface. Is this correct?
