Cisco 3640 Router - 2E2W with WIC 2A/S - not working?
jamesawoodward
Hi All,
I have two newly purchased (and very used) Cisco 3640 routers - each has a 2E2W Network Module and one WIC 2A/S. I can see both WIC 2A/Ss when I run a sho diag command, but I cannot confiure them as serial ports and do not see them in any of my other sho commands. Does anyone have any idea what the problem may be? Here's what I get from sho diag, and a few other things that may help:
sho diag
Slot 0:
Combo 2E, 2W Port adapter, 4 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.2 Board revision A0
Serial number 6995878 Part number 800-01171-04
FRU Part Number NM-2E2W=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 1E 01 02 00 6A BF A6 50 04 93 04 00 00 00 00
0x10: 50 00 00 00 98 02 06 17 FF FF FF FF FF FF FF FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
Serial 2A/S (12in1)
Hardware revision 1.0 Board revision B0
Serial number 33957102 Part number 800-03182-02
FRU Part Number WIC-2A/S=
Connector type PCI
0x20: 01 13 01 00 02 06 24 EE 50 0C 6E 02 00 00 00 00
0x30: 58 00 00 00 05 09 02 00 FF FF FF FF FF FF FF FF
Bob#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Bob(config)#int s?
% Unrecognized command
Bob(config)#int s ?
Async Async interface
BVI Bridge-Group Virtual Interface
CDMA-Ix CDMA Ix interface
CTunnel CTunnel interface
Dialer Dialer interface
Ethernet IEEE 802.3
Group-Async Async Group interface
Lex Lex interface
Loopback Loopback interface
MFR Multilink Frame Relay bundle interface
Multilink Multilink-group interface
Null Null interface
Port-channel Ethernet Channel of interfaces
Tunnel Tunnel interface
Vif PGM Multicast Host interface
Virtual-PPP Virtual PPP interface
Virtual-Template Virtual Template interface
Virtual-TokenRing Virtual TokenRing
range interface range command
Bob(config)#do sho ip int brief
Ethernet0/0 192.168.0.1 YES NVRAM up down
Ethernet0/1 192.168.1.1 YES NVRAM up down
Loopback4 4.4.4.4 YES NVRAM up up
Loopback5 5.5.5.5 YES NVRAM up up
Loopback6 6.6.6.6 YES NVRAM up up
Loopback7 7.7.7.7 YES NVRAM up up
Bob(config)#
5 Replies 5
ghostswitch
Do the modules work in any other router? And do any other modules work in this slot of this router?
Wow - thanks for your very quick response. I only have the two modules and the two routers (plus a 1602 and two 2516s). I bought the routers about 2 weeks ago, and just received the cables to connect them yesterday, so I'm not sure - I haven't disconnected anything yet.
Shouldn't I see Serial Interfaces ready to be configured if they're there and properly installed?
Thanks again!
Jim Woodward
Hi, jim
WIC-2A/S cannot be installed on an NM-2E2W; it is not supported. Please see the following link:
http://www.cisco.com/warp/public/107/wic-2as.shtml#fourth
To solve your problem, you have two options: get two WIC-1Ts and keep the NM-2E2W, or keep the WIC-2A/S and get an NM-2FE2W
SSLIN
SSLIN
good catch. rated as deserved.
Rick
Rick
Hi SSLIN,
thank you very much for your research. I will contact the vendor and see what they can do for me.
I'm thinking that the better of your 2 options would be to get an NM-2FE2W (albeit more expensive, but simply . . . better).
IDH (It does/did help)
Jim Woodward
