show users problem
Feb 22nd, 2008
hi, i'm having a issue with show users on a cisco catalyst 3750
i'm logging in with a local user and I have tried logging in with a tacacs and radius account, when I do a show users on the switch it doesn't show the username,
however on the cisco 1841 router I have it shows the user information all the time,
if there a command I have to use on the switch to make it show user information ie username used to login, when the show users command is issued. I have tried to compare the configs however all the generic info seems to be the same.
ROUTER#sh users
Line User Host(s) Idle Location
194 vty 0 admin idle 00:12:37 10.0.0.13
Interface User Mode Idle Peer Address
SWITCH#sh users
2 vty 0 idle 00:12:37 10.0.0.13
I hope this makes sense
craig.eyre Wed, 03/05/2008 - 12:57
I checked this on my 3750's and it works fine. Did you see if it's a bug in the IOS you are running? I'm running 12.2(40) SE
Craig
