ASA 5520 8.0(2) SSL problem
Feb 22nd, 2008
Hi All
I have ASA 5520 with 8.0(2) and using for SSL with 50 user liscence. SSL Clients are using Windows VISTA. Clients can either connect through Tunnel mode and Browser mode.
It works fine but suddenly ASA reject all the SSL sessions and even no new session can be established. For clients it gives "Logon Error".
ASA again start accepting SSL connections only after reload.
I am planning to upgrade it to 8.0(3) but not sure, if it will help to resolve this problem. Please suggest
rajbhatt Sun, 02/24/2008 - 23:59
What is the syslog error u are getting ?
Try term mon at level 7 and see what u are getting
Just verify the vpn simaltaneous logins is set to 50 ?
This is not in productions I guess as u are rebooting often :
What is the result of the output of
debug webvpn request
debug webvpn response
debug webvpn svc
Bharat Negi Mon, 02/25/2008 - 04:23
Hi Raj
Thanks for replying.
SSL login is set to 50.
Syslog and debug results in Radius authentication passed but no connection established. I have not recorded the same.
I am planning to upgrade it to 8.0(3). Once done will update for furhter issues.
