iscw ios feature set
Feb 23rd, 2008
I have a 2600 router with 128 meg of ram and 32 meg of flash. Anyone know what feature set I can use that would give me ssh, ios firewall, ids/ips & vpn features to test with?
The following featureset will do it, but no IPS support.
c2600-ik9o3s-mz.122-46a.bin requires 48MB DRAM and 16MB flash. This is an old image, but the latest you will get with the hardware you have. This will also mean that you may not support all features you need to.
Hope this helps
jlhainy Wed, 02/27/2008 - 05:46
Thanks! However, I did find one that had IPS support as well. I used the IOS feature tool to help me find a 12.3T version that had it.
