speed/duplex issue
cisco24x7
Level 6
Level 6
Can someone explain this:
Cisco catalyst 2960 shows interface as 100-full, but the Redhat Linux ES
version 3.0 box connected to the switchport G0/10 is shown as
100-half. Which one is the correct setting then? Everything is working
fine with NO CRC errors.
C2960#sh mac address-table int
C2960#sh mac address-table interface g0/10
Mac Address Table
Vlan Mac Address Type Ports
2 00a0.c90d.2a1d DYNAMIC Gi0/10
Total Mac Addresses for this criterion: 1
C2960#sh int g0/10
GigabitEthernet0/10 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0019.551b.d60a (bia 0019.551b.d60a)
Description: NGx R65 GW1 eth0
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:09, output hang never
Last clearing of "show interface" counters 00:00:58
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 19000 bits/sec, 22 packets/sec
5 minute output rate 163000 bits/sec, 105 packets/sec
5654 packets input, 550697 bytes, 0 no buffer
Received 160 broadcasts (0 multicast)
0 watchdog, 157 multicast, 0 pause input
10428 packets output, 5360846 bytes, 0 underruns
C2960#
[Expert@NGx-gw1]# ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised auto-negotiation: No
Speed: 100Mb/s
Duplex: Half
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Link detected: yes
[Expert@NGx-gw1]#
[Expert@NGx-gw1]# ifconfig eth0
eth0 Link encap:Ethernet HWaddr 00:A0:C9:0D:2A:1D
inet addr:192.168.1.201 Bcast:192.168.1.255 Mask:255.255.255.192
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:12982488 errors:0 dropped:0 overruns:0 frame:0
TX packets:3284111 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3363084973 (3207.2 Mb) TX bytes:1925104265 (1835.9 Mb)
Interrupt:11 Base address:0xdec0 Memory:f8001000-f8001038
[Expert@NGx-gw1]#
9 Replies 9
aijaz802
Please re-check that the cable going from the Linux box is directly connected to the Gig0/10 of switch without any intermediate hub/switch.
*aijaz*
The linux box is directly connected to the
Catalyst 2960 G0/10:
C2960#sh run int g0/10
Building configuration...
Current configuration : 141 bytes
interface GigabitEthernet0/10
description NGx R65 GW1 eth0
switchport access vlan 2
speed 100
duplex full
spanning-tree portfast
end
C2960#
The cable is also a good cable as well CAT 5+.
This cable works with other Cisco devices
without issues.
Any other ideas? Thanks.
CCIE Security
I think that this is related to auto-negotiation, as appears from your output, your linux box is configured with auto-negotiation. As a best practice both sides must be configured with auto-negotiation, or both should be configured with the same manual speed/duplex, since most of the devices return to half duplex if it is configured with auto-negotiation and the other end is manually configured.
BR,
Mohammed Mahmoud.
"I think that this is related to auto-negotiation, as appears from your output, your linux box is configured with auto-negotiation"
Huh? The interface is EXPLICITLY configured
for 100-full. See below:
[Expert@NGx-gw1]# /sbin/ethtool -s eth0 speed 100 duplex full autoneg off
[Expert@NGx-gw1]# /sbin/ethtool eth0
Settings for eth0:
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
Supports Wake-on: d
Wake-on: d
Link detected: yes
[Expert@NGx-gw1]#
I think Mohammed is right...
It seems that the linux box is set to manual with 100 MBPS n half....its NOT negotiating(its capable) as shown.. "Advertised auto-negotiation: No ". Try to set it to auto or make it 100-full.
Regards...
Settings for eth0:
Speed: 100Mb/s
Duplex: Half
Port: Twisted Pair
PHYAD: 1
Supports Wake-on: d
Wake-on: d
Link detected: yes
[Expert@NGx-gw1]#
It stays up a "full" for about 10 seconds, then goes back to "half". Weird part is
that there are no collisions on the catalyst interface. Very strange.
You probably won't see any errors on the Catalyst because that side is hardcoded to 100/full . If you want to leave the 2960 as is hardcode the nic card to 100/full . They must match on both sides . You may not see a whole lot errors until you start pumping larger amounts of traffic down that pipe and then you will really notice the performance degradation .
It is strange! But you just clear the counters 58 seconds ago.
In one implementation, I have a 3750 GE interface hardcoded 100Mbps/Full-duplex and the HP-Unix System Engineer forgot to hardcode the server NIC and left it in Auto/Auto, the HP-Unix NIC negotiated the link as 100Mbps/Half-duplex. The collission registered in the switch is high and accumulating very fast, on top of that the data transfer is very slow.
If you can't make the Linux NIC to 100Mbps/Full-duplex, replace/recrimp the cable and make sure its straight through cable.
BTW, just to confirm the following about the collission error, please check;
1. The interface in the switch is the correct interface where the Linux is connected
2. Make sure that the Linux is not using NIC-Teaming and the other NIC is currently active
3. If the Linux are in HA, the other box might be the active.
Dandy
1- Linux box is NOT NIC-Teaming. There is
ONLY 1 NIC in the box,
2- I hard code the Linux box to 100/Full with
this command:
However, the interface is still shown as
half. The catlyst is shown as 100/Full.
3- If this is true, I should get a lot of
errors on the interface, but I do not. I
am pumping about 90mpbs of ssh traffic
through this interface for 8 straight hours.
What makes it strange is that both the
Linux box and the Catalyst shows NO errors.
