Re: New Installation of AS5350XM
Feb 24th, 2008
I am installing a new AS5350XM which I am replacing with an existing AS5350. I need some help in the following task :-
1) I want to configure the clock from my E1 feature card. The command from the doc says
conf t
dial-tdm-clock priority {slot/ds1 port}.
But I am unable to enter the 'dial-tdm-clock' command on the CLI. It seems that the command does not exist. I am using the IOS version c5350-is-mz.124-10c.bin.
2) Do I need to configure the SPE setting for users to dial in via the modem or can I just ignore this piece of configuration ?
Pls advice,
Cheers,
- sn -
owillins Fri, 02/29/2008 - 07:20
  • Silver, 250 points or more
1.To troubleshoot your E1 or T1 controllers, first check that the configuration is correct.
2.Another common reason for failure is the dial-tdm-clock priority setting. The default setting is a free-running clock that causes clock slip problems if not set properly
3. Make sure you are running minimum 11.3(2)AA .
