E1 solution for voice and data
Feb 24th, 2008
Dear all,
I have three remote offices. they connected together with E1.
I have also three pbx in each location.
I want to use VWIC cards to integrate voice and data for this solutions.
is there any sample and web link to guide me?
Paolo Bevilacqua Mon, 02/25/2008 - 06:53
Hi, the best thing is you get a dual-port vwic card, and configure for voip. The smaller router you can use is a 1861, or a 2801.
This way the pbxs will have a full mesh link between themselves, and you can use all the bandwith saved for data.
hope this helps, please rate post if it does!
