Rob Huffman Sun, 02/24/2008 - 10:30
Hi Michael,
You have to configure a SSID first, then you should be able to turn up the Radio/Radio's;
Changes to the Default Configuration-Radios Disabled and No Default SSID
In this release, the radio or radios are disabled by default, and there is no default SSID. You must create an SSID and enable the radio or radios before the access point will allow wireless associations from other devices. These changes to the default configuration improve the security of newly installed access points.
http://www.cisco.com/en/US/docs/wireless/access_point/ios/release/notes/b38jebrn.html#wp147963
Hope this helps!
Rob
Rob Huffman Sun, 02/24/2008 - 16:51
Hi Michael,
You are most welcome :) Glad to be of some small help.
Take care,
Rob
