router ACL
Feb 24th, 2008
I am confused with the access-list requirement for IPS.
IPS device will create dynamically generated ACL to the router in the event that a signature is triggered. It requires an existing access-list defined as Pre-block access list and an existing access-list defined as post-block access list.
Does this mean that I need to set up at least 3 access-list on my router, one for normal use that is applied to the interface, another one to be defined as pre-block access-list on IPS device and a third one to be defined as post-block access-list on the IPS device?
owillins Fri, 02/29/2008 - 07:32
  • Silver, 250 points or more
Could you specify what device you are using and its configuration?
eppiet Fri, 02/29/2008 - 09:39
The router is a 2600 and ips is 4215. Currently I only have one set of access-list. That's why I don't understand how I can have a pre and a post access-list to be used by the IPS device.
