ASA 5520 AIP-SSM 10 Confusion about Recover
Feb 24th, 2008
The same commands for recovering the config are the same for pulling a system image. Do you pull a system image or push a backup config?
To install the AIP-SSM system image, follow these steps:
Step 1 Log in to the ASA.
Step 2 Enter enable mode:
asa# enable
Step 3 Configure the recovery settings for AIP-SSM:
asa (enable)# hw-module module 1 recover configure
Note If you make an error in the recovery configuration, use the hw-module module 1 recover stop
command to stop the system reimaging and then you can correct the configuration.
Step 4 Specify the TFTP URL for the system image:
Image URL [tftp://0.0.0.0/]:
Example:
Image URL [tftp://0.0.0.0/]: tftp://10.89.146.1/IPS-SSM-K9-sys-1.1-a-6.0-1-E1.img
Step 5 Specify the command and control interface of AIP-SSM:
