%SPANTREE-5-MSGAGEEXPIRY:
Feb 24th, 2008
Hi NetPro,
anyone who has experienced about this ?
i was wondering i have fixed the Root and Priority at Core-switch for all vlans. how come new root bridge will automatically changed ?
2008 Feb 24 16:06:01 GMT8 +08:00 %SPANTREE-5-ROOTCHANGE:Root changed for Vlan/Instance 71: New root port 2/1. New Root mac address is 00-0a-8b-04-02-00.
2008 Feb 24 16:06:17 GMT8 +08:00 %SPANTREE-5-MSGAGEEXPIRY: Msg Age timer expired on port 3/4 in vlan 71
2008 Feb 24 16:06:17 GMT8 +08:00 %SPANTREE-5-MSGAGEEXPIRY: Msg Age timer expired on port 1/1-2 (agPort 13/1) in vlan 71
2008 Feb 24 16:06:17 GMT8 +08:00 %SPANTREE-5-ROOTCHANGE:Root changed for Vlan/Instance 71: New root port 0/0. New Root mac address is 00-0a-8b-24-90-46.
2008 Feb 24 16:06:17 GMT8 +08:00 %SPANTREE-5-ROOTCHANGE:Root changed for Vlan/Instance 71: New root port 13/1. New Root mac address is 00-0a-8b-25-08-46.
2008 Feb 24 16:06:18 GMT8 +08:00 %SPANTREE-5-ROOTCHANGE:Root changed for Vlan/Instance 71: New root port 3/6. New Root mac address is 00-0a-8b-04-02-00.
2008 Feb 24 16:06:37 GMT8 +08:00 %SPANTREE-5-MSGAGEEXPIRY: Msg Age timer expired on port 3/6 in vlan 71
2008 Feb 24 16:06:37 GMT8 +08:00 %SPANTREE-5-ROOTCHANGE:Root changed for Vlan/Instance 71: New root port 0/0. New Root mac address is 00-0a-8b-24-90-46.
2008 Feb 24 16:06:37 GMT8 +08:00 %SPANTREE-5-ROOTCHANGE:Root changed for Vlan/Instance 71: New root port 2/2. New Root mac address is 00-0a-8b-25-08-46.
your reply will be very higly appreciated.
thanks ya.
Jack
Overall Rating: 3.4 (7 ratings)
akbindal Sun, 02/24/2008 - 20:20
Hi Jack,
To understand the messages and these changes you probably need to post the topology and the connected switches..however..these messages indicate that there might be switches in the spanning tree network which are trying to override the current root bridge for VLAN 71..
To isolate the same try to put "spanning-tree root primary vlan71" command on the switch which you want to make primary root in the entire domain for VLAN 71..so that it dynamically changes priority values to become root in the spanning domain..
Also you can try putting "spanning-tree root guard" (globally or on interfaces on which you want to block BPDU from other switches for this switch to become ROOT..) that you want to block from command to guard the current root from being changed in the current spanning domain..
I also think that as Max Age Timer is expiring check if BPDU's are being transferred in the network..
Akhil
ney25 Sun, 02/24/2008 - 20:46
Hi Akhil,
your info very helpful, currently i am using PVST and this is 2 Tier network only. basically i have set the vlan 71 as priority 8192 in the core switch.
so, from your msg you advice to configure " spanning-tree root primary vlan71 " . would it be any impaction to entire network ?
since you have mentioned Max Age Timer . anything to do with this ?
your reply will be highly appreciated.
thanks
Jack
akbindal Sun, 02/24/2008 - 20:54
Hi Jack,
I cannot suggest changes without a network diagram mentioning the current setup..but yes..if you would like to make the current switch as root for the VLAN 71 in spanning tree domain..it would only effect the VLAN 71 for root selection in spanning tree..so i would suggest to review your toplogy and select the best root bridge for VLAN 71 in your network..
spanning-tree vlan 71 root primary --this command when applied on a switch changes the bridges priority dynamically to select it as root bridge for VLAN 71..
Akhil
ney25 Sun, 02/24/2008 - 21:48
Hi Akhil,
again thanks for your helpful msg, i am curious about Spantree 71 took over by some other switch and it affected to some of my switch turn to Errordisabled .
" Feb 23 11:06:57.105: %UDLD-4-UDLD_PORT_DISABLED: UDLD disabled interface Gi0/1, unidirectional link detected
Feb 23 11:06:57.105: %PM-4-ERR_DISABLE: udld error detected on Gi0/1, putting Gi0/1 in err-disable state "
is this correct ?
regards,
Jack
akbindal Sun, 02/24/2008 - 22:26
Hi Jack,
The above messages suggest that UDLD was enabled on the links between switches and was put into error-disabled state when it recognised the unidirectional link..
Please refer to the following link :
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/udld.html
-- Here you can check how the links are connected through copper or fiber cables..normally it is enabled on fiber links..also check for duplex mismatches or problems on the interfaces..
Akhil
ney25 Sun, 02/24/2008 - 22:59
Hi Akhil,
the reason i asked this is because the logs file from core show "
2008 Feb 24 16:11:26 GMT8 +08:00 %SPANTREE-5-ROOTCHANGE:Root changed for Vlan/Instance 71: New root port 2/6. New Root mac address is 00-0a-8b-04-02-00. " so, when i trace from 2/6 , it shown connected to the switch wich i got the UDLD logs.
so, i got the feeling it's something to do with this.
your reply will be higly appreciated.
regards,
Jack
akbindal Sun, 02/24/2008 - 23:06
Hi Jack,
Cannot comment on the same without knowing the current network topology for the connected switches..
Akhil
Francois Tallet Mon, 02/25/2008 - 12:54
  • Gold, 750 points or more
It seems you have some trace enabled (not a Catos expert), and what you see is the detail of the root election after the root information has aged out. The root information aging out seems to be consistent with your UDLD issue: a link was brought down, and, as a result, the root bridge was not accessible any more.
The bridge has aged out the root information on the root port and just elected a new root port (2/1 was probably alternate discarding before).
Some other blocked ports are aging out the root information.
The root information has aged out on the root port and it has actually aged out on all the ports! The bridge thinks it is the root.
Some other bridge with a better priority than ours pretends to be the root (because it has also aged out the root information). We're considering it as the root right now, it's the best root we heard from so far.
A neighbor has not aged out the original root information, it just sent it to us, we are accepting this port as a root port
The information we had received in the previous step now aged out...
Back to thinking we are the root...
And then we're receiving better information from someone else.
All those messages don't really matter. With regular STP, the root information is disappearing from the network in 20 seconds (max age). Some port might need to unblock if there is some change in the final topology. It will 30 seconds to do so. The intermediate steps are not important, they depend on who is aging the root information first. What is important is that the new root bridge is finally taking over and imposing its topology.
Francois
ney25 Mon, 02/25/2008 - 18:34
Hi Francois,
your explanation really good and helpful, so is that any preventive guide ? because, this really affected my current network. i have few switches down caused by UDLD Port Disabled.
regards,
Jack
Francois Tallet Tue, 02/26/2008 - 12:54
Hi Jack,
The STP messages seem rather clear to me. I think they are a consequence of your problem, not the source. UDLD is supposed to detect unidirectional link failures (ie a link that is able to transmit in only a single direction while staying up). This is important because this kind of failure can cause loss of connectivity without reconvergence of the L2 control protocols, or even worse, introduce loops in your network. If you get this consistently on a link, I would suspect a hw issue.
Francois
ney25 Tue, 02/26/2008 - 17:33
Hi Francois,
thanks for your information, yes i do agreed with you. would it be possible this is caused by Bug ? because i noticed most of the UDLD detected at Core to Distribution layer. and currently my Core-switch running 7.6(12).
thanks a lot.
regards,
Jack
Francois Tallet Tue, 02/26/2008 - 17:37
Hi Jack,
It could be a bug indeed. I cannot rule this out. I'm not very knowledgeable in either CatOS or UDLD, so if someone has any experience in those kind of trouble, please help;-)
Francois
