Static NAT problem
Answered Question
Feb 24th, 2008
I have a problem with static nat i cannot assign IP address more than 8 for example
ip nat inside source static 172.19.134.109 10.116.116.1
ip nat inside source static 172.19.134.123 10.116.116.2
ip nat inside source static 172.19.134.137 10.116.116.3
ip nat inside source static 172.19.134.127 10.116.116.4
ip nat inside source static 172.19.134.6 10.116.116.5
ip nat inside source static 172.19.134.114 10.116.116.6
ip nat inside source static 172.19.134.124 10.116.116.7
ip nat inside source static 172.19.134.35 10.116.116.8
ip nat inside source static 172.19.134.34 10.116.116.19
the last 2 commands are not working what could be the problem? please advice
Correct Answer by connect2world about 8 years 11 months ago
There is no reason you can use the last 2 addresses unless they are taken by some other devices.
Overall Rating: 5 (1 ratings)
1lumkk Sun, 02/24/2008 - 21:29
Please append the debug output for that statement.
connect2world Sun, 02/24/2008 - 21:53
Are you subnetting 10.116.116.0 network using a 29 bit mask? If yes, 10.116.116.8 is not usable since it is a network id.
welaish77 Sun, 02/24/2008 - 22:04
!!! how to know that!? i will attach the router configuration and tell me there is no command that can issue on the router to know the subnet of the IPs.
connect2world Sun, 02/24/2008 - 22:20
What is the subnet mask for the 10.116.116.x network?Once you know that, it will tell you which address range can it exist.
Correct Answer
connect2world Sun, 02/24/2008 - 22:30
welaish77 Sun, 02/24/2008 - 22:31
then the problem from the other network side. thanks so much.
