CCM5: PSTN Dialing
Feb 24th, 2008
Friends,
I am working on voice setup where I am configuring gateways and CCM5. I have both PBXs with analog phones and Call manager with IP Phones. Now my fist phase is working fine scenario you can see below:
phone1---pbx1---router1------router2----pbx2---phone2
pbxs are connected with router with e1 pri and routers are connected with each other via e1 link. Site1 code is 1000 and site2 code is 2000
site1 config ----
dialpeer 2000 voip
destinationpatern 2000
session target router2 ip
site2 config ----
dialpeer 2000 pots
destination 2000
port 1/0:15
forward digit all
so user dial 2000 and extention of any length after site code, it worked fine. Means in configuration I am not matching all digits so rest of digits forward after dialpeer matches. This thing is very useful for pstn dialing as I don't need the configure multiple dialpeer of different lengths.
Now Issue is that it is not working in the scenario in which I have CCM and gateway.
IP Phone----CCM-----------Gateway----------PSTN
I configure destination pattern 9 on ccm that pointing to gateway. Then I configured a dialpeer on Gateway that will forward call to pri with pstn.
Gateway config ---
Dialpeer voice 9 pots
Destination-pattern 9
port 1/0:15
forward digit all
But it is not working. As I press 9, I get silly tone. Please help me get this issue resolved
Waiting.....
Best Regards
Rameez
pklos Mon, 02/25/2008 - 00:12
  • Silver, 250 points or more
AFAIK, you should have:
Destination-pattern 9T
regards,
PK
