Pots to use group of ports at the same time
Feb 24th, 2008
Have a router connected to a paging system using E&M ports. Just using the output wires from the E&M in the paging system.
Is there a way when I call a number for example 789 which needs to go to 3 different zones connected to 3 different E&M ports that the router will sieze all 3 ports and output the audio across all 3 ports at the same time.
