DMVPN Area
zeeshan2007
Dear Sir
i would like to know that is there any limitation in DMVPN with OPSF are?
I hired that DMVPN only run in OPSF single are.
could you plz clear me.
your response will be higly appreciated .
aghaznavi
Level 5
Level 5
You can do OSPF network type as broadcast, you can get spoke to spoke direct communication or you can redistribute routing update into some other protocols.
thanks sir. i have one more question regarding DMVPN. I have Hub router 3845 and different 30 braches .some of these braches using DSL as a primary link. but some of them are using DXX as a primary link .
So my question is can my single HUB router will use a single interface for my 30 branches?
i am confuse that DXX need physcial interfaces, and hub also need different physical interfaces for branches for DMVPN?
HUB 3845
spoke routers 1841 (some are using DSL as a primary link and some of them are using DXX as a primary link)
OSPF is routing protocol with area 0,area10,area20.
sir your response will be higly appreciated.
