ASA 5510 InterVlan Routing and internet access
Feb 24th, 2008
My topolgy is like this.
ISP--->Router--->ASA5510 Firewall--->cisco2960 48 port switch in VLAN--->Small 8 and 16 port switches to for respective VLAN.
Here Want to achieve internet access and separate network for individual department.
Got the public IP on the outside interface of the firewall say (59.x.x.x) and configured it.Now to achive the desired result I am planning to have something like below menteioned config on my ASA.
Assume you have 4 networks 2.2.2.0, 3.3.3.0, 4.4.4.0, 5.5.5.0
ASA5510
interface ethernet0/2
speed 100
duplex full
nameif LAN
security-level 50
no ip address
interface Ethernet0/2.2
vlan 2
nameif vlan2
security-level 50
ip address 2.2.2.1 255.255.255.0
interface Ethernet0/2.3
vlan 3
nameif vlan3
security-level 50
ip address 3.3.3.1 255.255.255.0
interface Ethernet0/2.4
vlan 4
nameif vlan4
security-level 50
ip address 4.4.4.1 255.255.255.0
interface Ethernet0/2.5
vlan 5
nameif vlan5
security-level 50
ip address 5.5.5.1 255.255.255.0
global (outside) 1 interface
nat(vlan2) 1 2.2.2.0 255.255.255.0
nat(vlan3) 1 3.3.3.0 255.255.255.0
nat(vlan4) 1 4.4.4.0 255.255.255.0
nat(vlan5) 1 5.5.5.0 255.255.255.0
And on switch side:
Switch_2960:
vlan database
vtp transparent
vtp domain test_lab
vtp password cisco
vlan 2 name VLAN2_2.2.2.0/24
vlan 3 name VLAN3_3.3.3.0/24
vlan 4 name VLAN4_4.4.4.0/24
vlan 5 name VLAN5_5.5.5.0/25
etc....
Interface fastethernet0/48
Description trunk_Connection_ASA_Ethernet03
speed 100
duplex full
switchport mode trunk
switchport trunk allowed vlan 2,3,4,5 etc..
And then say from port no. 2 cable going to small 8or 16 port linksys switch and so on for port 3 and 4.
Questions:
1. Do I need to configure anything else on ASA side as far as natting is concerned.I just want to allow internet access to all the VLAN.
2. Can I keep my cisco 2960 L2 switch as VTP Server mode?
3. Will the small switches(8/16 port of linksys) interfaces will allow the traffic to flow desired subnet.These small switches are unmanaged?Will this work without trunking.
Suggest me same configuration scenrios for the same as well.
Thanks In advance.
Reg,
Sushil
