Problem in Router 1841 - Route-map function
Feb 25th, 2008
hi , everybody
please help me in cause,in my school has 2 adsl [dynamic IP from ISP] i connect 2 line into my router [R1841+2WIC-ADSL] my config in file.
if 2 link is normal, everything is good but
in case when link 1 down, service in route-map on link 1 [every service not include ftp] it not take to link 2 , by the way in case link 2 down, service in route-map on link 2 [ftp only] it not take to link 1
please help me because now internet in my school slow for tranfer homework of student.
Thank you so much.
shivlu jain Mon, 02/25/2008 - 00:44
  • Silver, 250 points or more
can you send the output of show policy-map interface x/x
regards
shivlu
sweetpigy Mon, 02/25/2008 - 01:03
JS#sh policy-map interface
JS#
it's not appear.
JS-Siam#sh policy-map interface fa0/0
JS-Siam#
same not appear.
sweetpigy Mon, 02/25/2008 - 01:07
some msg in "debug policy"
*Feb 25 09:04:15.282: IP: s=192.168.0.201 (FastEthernet0/0), d=64.233.189.104 (Dialer0), len 40, FIB policy routed
*Feb 25 09:04:15.282: IP: s=192.168.0.201 (FastEthernet0/0), d=64.233.189.104, len 40, FIB policy match
*Feb 25 09:04:15.282: fibidb->namestring: Dialer0
*Feb 25 09:04:15.282: ipfib_policy_set_interface_lookup: tag_ptr: 0x0
*Feb 25 09:04:15.282: adj 0x0, NULL
*Feb 25 09:04:15.326: IP: s=192.168.0.201 (FastEthernet0/0), d=192.168.10.149, len 52, FIB policy match
*Feb 25 09:04:15.326: fibidb->namestring: Dialer0
*Feb 25 09:04:15.326: ipfib_policy_set_interface_lookup: tag_ptr: 0x0
*Feb 25 09:04:15.326: adj 0x0, NULL
*Feb 25 09:04:15.326: IP: s=192.168.0.201 (FastEthernet0/0), d=192.168.10.149 (Dialer0), len 52, FIB policy routed
*Feb 25 09:04:15.766: IP: s=192.168.0.201 (FastEthernet0/0), d=192.168.0.255, len 78, policy match
*Feb 25 09:04:15.766: IP: route map Input, item 10, permit
*Feb 25 09:04:15.766: IP: s=192.168.0.201 (FastEthernet0/0), d=192.168.0.255 (Dialer0), len 78, policy routed
*Feb 25 09:04:15.766: IP: FastEthernet0/0 to Dialer0 192.168.0.255
*Feb 25 09:04:15.814: IP: s=192.168.0.201 (FastEthernet0/0), d=192.168.10.149, len 52, FIB policy match
*Feb 25 09:04:15.814: fibidb->namestring: Dialer0
*Feb 25 09:04:15.814: ipfib_policy_set_interface_lookup: tag_ptr: 0x0
*Feb 25 09:04:15.814: adj 0x0, NULL
sweetpigy Mon, 02/25/2008 - 01:15
JS#sh route-map
route-map ISPB, permit, sequence 10
Match clauses:
interface Dialer1
Set clauses:
Policy routing matches: 0 packets, 0 bytes
route-map ISPA, permit, sequence 10
Match clauses:
interface Dialer0
Set clauses:
route-map Input, permit, sequence 10
Match clauses:
ip address (access-lists): Permit_ISPA
Set clauses:
interface Dialer0 Dialer1
Policy routing matches: 16866 packets, 3434386 bytes
route-map Input, permit, sequence 20
Match clauses:
ip address (access-lists): Permit_ISPB
Set clauses:
interface Dialer1 Dialer0
Policy routing matches: 3 packets, 198 bytes
JS#
this is shop route-map
