LMS 3.0 + emtpy syslog report
Feb 25th, 2008
We have a problem with CiscoWorks LMS 3.0.
The switches and routers are sending syslog messages to the CW Server. This works fine. I see the received syslogs by using "logview.exe" or by opening the syslog.log on the CW Server.
But the syslogs are not available in CiscoWorks itself. I can generate an syslog report and it is empty, but it shouldn't because i see a lot of messages which should be seen with a syslog report.
does anybody know this problem.
ps. dfm also doesnt work properly.
yjdabear Mon, 02/25/2008 - 07:31
Do you see any host subscribed in RME > Tools > Syslog > Syslog Collector Status? What does your /var/adm/CSCOpx/log/SyslogCollector.log say?
Joe Clarke Mon, 02/25/2008 - 09:25
Actually, NMSROOT\log\SyslogCollector.log on Windows. Additionally, the output of a pdshow would be useful.
markusspitzli Mon, 02/25/2008 - 23:34
Thanks for your help.
I have solved the problem by myself. I had to uninstall the .NET Framework 2.0 and reinstall CiscoWorks.
karima.zaydi Tue, 02/26/2008 - 04:52
I have the same problem, the backup directory is empty.
I send you the SyslogCollector.log and the pdshow output
Joe Clarke Tue, 02/26/2008 - 23:45
I don't see any errors here. to what backup directory do you refer? As was noted by the creator of this thread, having .NET 2.0 SP1 or higher along with DFM can cause socket starvation which can lead to other LMS daemons to fail. If you have .NET 2.0 SP1 or higher, uninstall it, and restart dmgtd.
