load balancing layer 2
Feb 25th, 2008
Hi all, can anyone tell me if we can load balance at layer 2 ? I have used a nortel smlt solution before, but I see cisco does not do this ? is there any reason, and does etherchannel load balance at layer 2 ?
aijaz802 Mon, 02/25/2008 - 02:06
  • Bronze, 100 points or more
Ether channel allows load sharing/balancing of traffic among the links in the channel as well as redundancy in the event that one or more links in the channel fail.
Rate if it helps...
Best Regards,
*aijaz*
royalblues Mon, 02/25/2008 - 03:21
  • Green, 3000 points or more
Carl,
Cisco switches do not support anything of the sort of SMLT.
If you have two redundant links from your access switches to the 2 distribution switches, the only way to loadbalance and utilize the links is to configure the dist switches in such a way that they are primary root for a set of vlans and secondary for the other
Narayan
Joseph W. Doherty Mon, 02/25/2008 - 05:00
As Aijaz mentions, channeling will L2 load balance between logical switches. (NB: take careful note of which hashing method is used - they often offer several choices.)
A variation of what Narayan suggests, if trying to load balance, again L2, between a logical edge switch and two upstream switches, and if using multiple VLANs, Flexlink would support static load balancing by manual configuration of which VLANs transverse which link.
