Specifically set AP failover to WLC
Feb 25th, 2008
Hi all,
My case is like as below:
2 WLC, WLC-4402-25-1 & WLC-4402-25-2, are implementated. There are a total of 30 APs. In case that one WLC is down, the remaining WLC cannot cater for all 30 APs.
Here is my question:
Can i specifically set which AP can failover to another WLC, which AP cannot failover.
Thanks all,
Overall Rating: 4 (1 ratings)
Scott Fella Mon, 02/25/2008 - 14:08
The ap's you do not want to failover, you should not configure the secondary WLC, but configure a false entry. This way those ap's try to join a WLC that is not there while the others are able to join. I believe you can also configure on the WLC which ap's can associate to that WLC.
eric.huihk Mon, 02/25/2008 - 19:52
Thanks Fella5.
Would you kindly show the configure guide that WLC can be set to let AP associate?
eric.huihk Mon, 02/25/2008 - 20:09
Hi Fella,
Per you link, there is a method "Using the Internal Authorization List on the WLC" which will not need external radius server.
This solution seems workable. I will try later. Thanks.
Scott Fella Mon, 02/25/2008 - 20:42
I don't know if that will work for you, but if it does then great. like I mentioned earlier, the easiest is setting the secondary controller on the 5 ap's that you don't want to join the wlc during failover to a bogus name. this should give your ap's enough time to all join except for those 5.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
