ethernet and ip headers
Feb 25th, 2008
Hi all, i know this is a very basic question, but can anyone tell me what the ethernet header is, and what it contains and used for, and also the same for the ip header ?
carl_townshend Mon, 02/25/2008 - 05:50
when the router receives the packet and needs to forward it, I have seen that it needs to rebuild the header, is this the layer 2 ethernet header, ie next hop mac address ?
royalblues Mon, 02/25/2008 - 07:14
The header would differ based on the connection the router has..
If the router needs to forward a packet out its interface which is serial, then it would build a HDLC or PPP header, similarly FR header for frame-relay. If it is ethernet, then it would be a ethernet header with the next-hop mac addresss as the destination MAC
