02-25-2008 03:54 AM - edited 03-11-2019 05:08 AM
PIX Devices Running Versions 6.2 and 6.3
"Issue the activation-key command in order to change your activation key if the PIX currently runs versions
6.2 or 6.3." Why do I have to do this ? Thx, Peter@it-123.co.uk
02-29-2008 07:54 AM
Reason for your question is "Updates the PIX Firewall activation key unless there is a mismatch between the Flash memory and running PIX Firewall software versions".
Refer the pix 6.3 command reference for more information
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/ab.html#wp1037845
Log in to Community
