SSO for CCM 5.1 TAPI ?
Feb 25th, 2008
I've installed the CiscoTSP-Version 5.1(1.1) with the CCM 5.1.
My problem is, that i've a w2k domain with passwordchange every 90 days.
So when the user changed the windows password the problem is that they have to change the password also in the TSP-Client. Is there a client or a way for a sso ?
Anonymous (not verified) Fri, 02/29/2008 - 07:56
Download the TSP plug-in from the CallManager and reinstall it at the Client PC. -If needed reset the End User Password and update the TSP configuration with it. Make sure the user you are using has the device assigned to him via the
CallManager End.
louis.engelbrecht Fri, 09/12/2008 - 07:41
Did you ever get an answer for this.
we are having the same issue. CUCM 6.1 with AD integration. which means that passwors change frequently.
Carsten Radke Sun, 09/14/2008 - 22:03
sorry, but i never get an answer.
Could you contact me if you have a way to do it ?
I'm going to change to CCM 6.1 in about 3 weeks.
kind regards, Carsten Radke
