CSICO Hidden Commands
Feb 25th, 2008
  • Gold, 750 points or more
Hello All,
Have someone come through various "CISCO Hidden Commands" which are normally used for Engineering Purpose.
Kindly attach / POST some Useful Commands for Network Engineering Purposes.
Thanks in Advance.
Best Regards,
Guru Prasad R
Overall Rating: 5 (4 ratings)
guruprasadr Mon, 02/25/2008 - 20:40
Dear Mohammed Mahmoud,
Thanks for your Link and it's very Useful.
>> Have rated your POST.
Dear All,
I would like to invite everybody, Kindly come forward and share any such Useful Link you have come through for CISCO Undocumented (HIDDEN) Commands.
Best Regards,
Guru Prasad R
mohammedmahmoud Tue, 02/26/2008 - 00:24
  • Green, 3000 points or more
Hi Guru,
You are very welcomed, as i've said before to Jon, this is the beauty of NetPro, sharing thoughts, information, and experience.
BR,
Mohammed Mahmoud.
Danilo Dy Tue, 02/26/2008 - 21:19
  • Blue, 1500 points or more
Hi Guru,
I'm not sure what exactly you mean of hidden command. i.e.
1. Not shown in the configuration
2. Not shown in "?"
3. Not documented by Cisco
For one and important, when you plug-in a VPN Accelerator to a router, execute "crypto engine accelerator" to enable it. In older IOS, this command is not shown in the config, not sure if this is shown in 12.4 - I haven't tried.
Dandy
