serial link interface ( serial and protocol both up) but CTS= down
Feb 25th, 2008
Hi all,
can any body help us regarding serial link problem
serial link detals are as follows
Serial0/0/1 is up, line protocol is up
Hardware is GT96K Serial
Description: **** NAGPUR AOB_DC TO MUMBAI COB RIL Link 6 ***
Internet address is 1.1.1.5/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP Open
Listen: CDPCP
Open: IPCP, loopback not set
Keepalive set (10 sec)
Last input 00:32:20, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:52:04
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
1337 packets input, 1509392 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1337 packets output, 1509392 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=down
here in last raw CTS is down === is their any problem with the CTS is showing down....
lamav Mon, 02/25/2008 - 07:37
What kind of router is this?
Are you using an internal CSU/DSU or external?
Typically, the CTS (clear-to-send) signal is generated by the DCE (CSU/DSU, modem, etc) as a response to the DTE's RTS (request-to-send). After the DCE detects carrier and waits a few milliseconds for it to stabilize, it will send the CTS signal to the DTE.
Your CTS should be "up."
Is this interface passing traffic?
Whats on the distant end and can you ping it?
Victor
