Cisco IPS4240 and IPS Event Viewer
Feb 25th, 2008
Good morning
I have in production a Cisco IDS 4235 that will be replaced with a Cisco IPS 4240
At today the 4235 works very well with Cisco IPS Event Viewer 5.2(1); also the model Cisco IPS 4240 will work well with Cisco IPS Event Viewer 5.2(1) ???
I should mantain in work the Cisco IPS Event Viewer 5.2(1).
Any information that you can send me are welcomed.
Cheers
Davide
scothrel Mon, 02/25/2008 - 06:33
Davide,
The IEV 5.2 product will work fine with the 4240. It's limitations are software version based, not platform. IEV 5.2(1) works with IPS 5.1(x) and 6.0(x)
sercopi Mon, 02/25/2008 - 06:45
Hi scothrel
thanks very much for your answer.
I have another question; I can also use Cisco IPS Event Viewer 5.2(1) with SSM-AIP-20 (for ASA5540) ???
Thanks in advance.
Davide
sercopi Mon, 02/25/2008 - 07:21
Hi scothrel
Thanks in advance.
Davide
marcabal Mon, 02/25/2008 - 08:11
Yes, IEV 5.2(1) will work with any IPS sensor models running versions 5.1(x) or 6.0(x).
