SIP SRST Problems
Feb 25th, 2008
We are having problems implementing SRST with telephones using SIP.
SCCP telephones work fine when CCM goes down and register with SRST. Calls are made normally. But SIP phones (we are using 3911 phones) dont register. Navigating throw the phone menu, in configuration-->network-->ccm5 is the name of our SRST GW. The name but not the IP address.
We are running CCM 6.0.1 and our GW is a 2821 (IOS version 12.4-15T3)
We are working without a DNS server in the network.
CCM IP: 192.168.101.251
SRST config:
voice service voip
sip
registrar server
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
voice register global
system message Conectado a sistema SRST
max-dn 192
max-pool 58
voice register pool 1
id network 192.168.101.0 mask 255.255.255.0
number 1 1...
preference 10
proxy 192.168.101.251 preference 1
voice-class codec 1
sip-ua
refer-ood enable
call-manager-fallback
max-conferences 16 gain -6
transfer-system full-consult
user-locale ES
timeouts interdigit 6
ip source-address 192.168.101.246 port 2000 strict-match
max-ephones 48
max-dn 192
system message primary No conexion CallManager Central
system message secondary SRST activado
CAn someone help us please?
Thanks in advance.
Salud.
Overall Rating: 5 (1 ratings)
sergio.ambrona Mon, 02/25/2008 - 09:11
We have found the problem.
In our CCM configuration we have defined the SRST reference with the hostname and IP of the GW. We have changed the name and put in that field the GW ip address and now it works.
It seems that CCM send the hostname instead of the ip address as SRST refernce to SIP Phones, so if you dont have a DNS server in your system the phone can not register with SRST.
Salud.
