Anitvirus on Ciscoworks
Feb 25th, 2008
Is there a supported Antivirus product for LMS 3.0? I had Mcafee running, but it was giving me all kinds of issues. Is there a supported product, and is there any documentation that shows what is/is not supported?
Joe Clarke Mon, 02/25/2008 - 09:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
We don't officially test with any AV software. Internally, we use McAfee, but it is recommended to disable it entirely for installations, and to disable on-access scanning of NMSROOT.
g-pate Mon, 02/25/2008 - 09:24
The customer is a bank and security concious..is there any product they can install. How about CSA at least? Are there any type of exeptions that can be put into Mcafee? When I had it running, it caused the services to take forever to start amongst other issues.
Joe Clarke Mon, 02/25/2008 - 09:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
CSA has been tested with CSM, but not LMS. I would caution against it. You can enable the host-based Windows firewall provided you open up all of the necessary ports. As for McAfee exceptions, excluding NMSROOT from on-access scanning is really the only thing that's needed.
