abinjola Mon, 02/25/2008 - 07:42
for inbound access all the ports are implicit deny unless you open any explicitly
daveshimp Mon, 02/25/2008 - 07:51
I don't mean allowing it through the firewall. I want to disable the smtp logging service so port 25 does not show as open on a port scan of the ASA.
daveshimp Mon, 02/25/2008 - 12:52
Here is my dilemma. When I run Harris Stat against the ASA it comes back with 2 open ports that I need to close. 25, 110. I do not have any server addresses configured on the ASA and want to close these ports.
Is this even possible? I can't find any documents to suggest that is and I can't find the commands that would do it either.
