Firewall rule help
mic.adrian
I'm pretty new on using Cisco routers, the guy that was in charge of this left and I'm supposed to take care of our Cisco 2811.
I'm trying to add a rule that allows unrestricted access from the whole subnet 192.168.0.0 /255.255.0.0 to certain range of IPs for example: 65.110.162.168 /29 (255.255.255.248)
I'm using Cisco SDM for this.
I'm able to add the rule and apply changes, but after I do an " Write to startup config" the rules changes automatically to a different IP, like this 1.0.0.0 or 5.0.0.0 and the subnet remains unchanged.
The rule looks like this:
Source: A Network = 192.168.0.0
Wildcard mask = 0.0.255.255
Destination: A Network = 65.110.162.168
Wildcard mask = 248.255.255.255
Protocol and Service: TCP
I have no idea what is happening and I would appreciate your help on this.
Thanks in advance.
Adrian
Jon Marshall
Adrian
Are you entering the wildcard mask of 248.255.255.255 ? or is that what the SDM is entering for you.
If it is you that is an incorrect wildcard mask. It needs to be
0.0.0.7
Jon
I'm entering the wildcard mask. Why it should be 0.0.0.7? I'll have to create multiple rules that have different kinds of masks....so I need to understand why is like that.....
Thank you for your answer....
Adrian
Adrian
Routers use inverse masks in access-lists so
192.168.0.0 subnet mask = 255.255.0.0
Subnet mask means the first 2 octets must match ie. 192.168.
The 3rd and 4th octet can be anything.
65.110.162.168 subnet mask 255.255.255.248
1st, 2nd, 3rd octect must match and only the last 3 bits in the last octet will change ie.
128 64 32 16 8 4 2 1
1 1 1 1 1 0 0 0 = 248
Last 3 bits ie. 4 + 2 + 1 = 7
Now an inverse mask is just the opposite of a subnet mask so
192.168.0.0 255.255.0.0 =
192.168.0.0 0.0.255.255
That one is easy because you just change 0 to 255 and 255 to 0
65.110.162.168 255.255.255.248 =
65.110.162.168 0.0.0.7 (7 because of the explanation above).
Now if that has totally confused you here is a quick way to do it
Whenever you see 255 change it to 0 and vice-versa.
Then
256 = 248 = 8 - 1 = 7
so 255.255.255.248 = 0.0.0.7
In the same way a subnet mask of 255.255.255.192 =
256 - 192 - 1 = 63 so inverse mask =
0.0.0.63
Jon
Thanks a lot.....that makes sense for me.
Adrian
