disable callwaiting beep on CME
Answered Question
Feb 25th, 2008
All, I have a client that wants to disable the callwaiting beep when a call comes in. I have seen where you can disable the ring, but I have not seen where you can disable the call waiting beep. Do any of you have any idea how it can be done, or if it can be done? Thanks for your help.
Correct Answer by Michael Owuor about 8 years 7 months ago
You could do this using the 'no call waiting beep' command under the DN in question.
See also:
Overall Rating: 5 (1 ratings)
