ASA5505 unable to get DHCP assigned IP from Cable provider- urgent !!!
Feb 25th, 2008
Hi All,
ASA 5505- ver 7.2(3).. unable to get DHCP ip from carrier. A laptop can get when directly connected to cable.
ASA configured with :
interface Vlan2
description :internet
nameif outside
security-level 0
ip address dhcp setroute
dhcpd auto_config outside
The below I found in the Forum did not qwork:
7.2.3 or later you have a checkbox in ASDM Configuration / Interfaces / Outside / Edit / General. Check the value in "For the client identifier in DHCP option 61" - "Use Mac address".
Thank you
mvsheik123 Mon, 02/25/2008 - 10:30
I cannot believe this..cable modem reset worked. Not sure why Latop was able to get IP with nothing done...
Thank you
