IPSEC with router and asa 5510
rlloveras
Hello All,
I am having problems connecting ipsec l2l. I have configure a router and asa 5510 to do ipsec between them but it seems to fail on phase 1. I check already and i am 100% sure the key matches. Can you some shed some light on the issue i am having. Here is the ouput debug i am getting from both system.
Thank you
johnd2310
Level 8
Level 8
Do the isakmp policies match on both devices? what ios version are running on the router and asa5510
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
Thanks for your rapid response john2310. I was working on it yesterday and i got it up and running. It was the isakmp policies that was messing up.
Thanks again
